All you do is splice into the exsting wire's lights that are in the floor board lights(which I also replaced with blue{pic included})Run the wire down the gunnel wall into the back of the boat.Then drill a small hole into th bottom of the blower vent and And run your wires up into the vent. Place two lights on each side of the vents, Solider and heatshrink your connections then use a black foam tape to cover your wire and
Bam !!
My e-mail is
neil@smithwarenetworks.net if you have any more questions
