I've wakeboarded behind IOs for about 8 years - I finally upgraded to a V-drive last year. IOs are difficult to maintain speed. The best solution that I found, to solve the speed problem, was to change the prop to the lowest pitch you can find. I suspect that your boat is outfitted with a 21" pitch prop. Drop back to an 18 or a 19. It'll pull the weight out of the hole quicker too. You'll loose your top-end speed. Though the frustration you'll save is worth it. I never ran Perfect Pass in the IOs - probably would help. We always throttled by RPM and by ear. After long enough you can distinguish 50rpm of engine sag by ear. While pulling an aggressive rider, we would always compensate by adding throttle as they cut into the wake. Then ease off as the boat recovered. These are very subtle throttle corrections. Ask your dealer if they will let you demo props before you buy them. some will. Try an 18", a 19" and see if you can try a Cupped 18 or 19. Depending on your boat, one prop will make all the difference. I know, I've been through about 9 props or so (grin) In my experience, Trimming never accomplished much. It'd make the wake 'peaky' and cause the water to curl over the top of the wake. Plus, while trimmed up, the boat would roll left and right as the skier pulled on the rope– This deforms and flattens the wake on the side they are on. The best wake was a result of full trim down. The only sure-fire way I found to enhance the wake was weight. We'd have to run about 75/25 rear to bow weight. We'd top out at about 1000lbs in my IOs, at that weight they had a hell of a time pulling out of the hole. Also, remember that the big wakes behind these competition boats are created by 1000-3000lbs of weight. To sum my $.02: Prop it down, weight it all the way up, trim it all the way down. good luck
