Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through March 23, 2006
Old     (bendow)      Join Date: Sep 2005       02-25-2006, 2:40 PM Reply
I was just curious how far out and what degree you guys set your bindings. I usually ride all the way out, but I got some LF bindings and they have 2 holes to put the screw through. I can't decide if I should put it in the second or the first hole.
Old    walt            02-25-2006, 2:42 PM Reply
I set mine all the way out and really ducked out.
Old     (mjmurphy53711)      Join Date: Mar 2004       02-25-2006, 2:55 PM Reply
im with walt.
Old     (bendow)      Join Date: Sep 2005       02-25-2006, 3:08 PM Reply
what do you mean buy "really ducked out" like 14,15,90 degree?
Old     (ttuclint)      Join Date: Sep 2003       02-25-2006, 3:29 PM Reply
pigeon toe stance.
Old     (thane_dogg)      Join Date: Jun 2002       02-25-2006, 3:54 PM Reply
I put mine all the way out with both feet ducked evenly at 16°. Usually about 10° is a good starting point. Then go ride, make a hard heelside cut and lean over backwards and lay your head back and see if your comfortable.
You can also stand on your bed, or couch, or coffee table, and jump off, and do your best to land in a stance where if I was to push you instantly you wouldn't fall over. Look at your feet then mimic the position on your wakeboard in terms of angle and distance apart.
Old    walt            02-25-2006, 4:38 PM Reply
The inside screw says 20% and the out side says 30% on my lead foot.
Old     (westsidarider)      Join Date: Feb 2003       02-25-2006, 7:49 PM Reply
i ride all the way out and completely ducked outward
