Old     (bigshow)      Join Date: Feb 2005       07-04-2006, 7:38 PM Reply
My oil bearings have view windows. One of the widows looked bright, almost white. I drained all four and refilled all four hubs. Actually I flushed the white one; that is, emptied, filled, emptied and refilled. Look at the difference in color from the hub with the white window and another hub. The white bearing oil is from water seeping into the hub, the dark color oil is from a healthy hub. The manufacturers data calls for 50 weight oil, will SAE 20W 50 be OK?
It’s mid season folks check your gear.
Old     (bob)      Join Date: Feb 2001       07-07-2006, 12:23 AM Reply
I dont think you want to use the 20W50 as it can act like 20w when at lower temps thereby leaking out. In a pinch it would be fine but for a permanent install use the 50 weight
