I have the tower and visability is not an issue. My biggest complaint is that it is a pain to put up. To do it by myself I hook a rope from the tower to my winch and use that to raise the tower, then slide the pins in. The problem is that the pins never seem to go in without alot of hassle. It also sticks up about 4 inches above the windshield, which means it won't go into the 7' garage without some work. I used to have to deflate the tires, lower the jack all the way, and have someone hold the tower in just the right position and it would still rub on the way in. I have since removed the trim from my header and I can get it in without letting air out of the tires, but it's still a pain.
