With your “ Perfect pass”, assuming you mean your paddle wheel, which will not perform like GPS based
Two solutions, switch to rpm mode which I do not recommend
For surfing you need to have a long steady slow movement from top all the way to WOT ( wide open throttle ). If you mess around and try to throttle position higher than WOT it can surge too fast when you finally go to WOT or don’t
For riding if you are with wedge and/or rear ballast heavy you feather ( not stupid slow) the throttle speed up getting boat to plane but not quite letting cruise take over by watching speed on gauge to slow it’s approach to the set speed. Your trying to get just up to the set speed and only over shoot it a small amount where it will settle back down without surging or failing to lock in. I usually don’t go to WOT riding but the wife does I think to just does it to get plane and when she attempts to back off she can’t do it quick enough and she usually goes a few mph higher but since she has been coming off WOT or close to it , it will settle back in on the first attempt when we are riding at higher speeds like 20++, Just as long as you have been feathering back in throttle the over shout happens but it locks in on first try
Perfect pass is the marriage saver as it is known and throttle control or paddle wheel comes with limitations and technique you have to master
Took my wife forever to learn to pull me skating slowly like 16 mph with wedge and/or ballast snd not overshoot badly snd then when it settled it surges back and forth
Install PP or learn these techniques , good news if your on a river with current paddle wheel works very well and can be the preferred cruise in this situation.
