Old     (Gotmods)      Join Date: Nov 2012       02-23-2017, 7:14 PM Reply
My head unit crapped. I have a clarion eq. If I get the 420bt is it a 1 and done. Or is the Exile media center the way to go and run it with my clarion?
Old     (chpthril)      Join Date: Oct 2007       02-23-2017, 7:59 PM Reply
If you arent looking for AM/FM, CD etc, then the WS-420BT or WS-220BT would replace the head unit and the clarion eq. Or, for the same price, go with the WS-420SA and the Wet Sounds BTSW blue tooth rocker or BTVC.
The Wet sounds marine zone volume controls have a coated BCB, master volume, tower and in-boat volume rather than fade. A true sub level control without the non-defeatable fixed sub low-pass x-over. The 220 has 4 zone control and the 420 has a dual 4 band EQ compared to the single eq of the clarion and others. With them, if you EQ the towers, it effects the in-boats and visa versa. With the Wet Sounds EQ, you can tune the tower zone independent of the in-boats. Cant do that with any other.
JL and Metra also offer the same media center if that route still interests you.
Old     (wakebrad)      Join Date: Aug 2005       02-24-2017, 8:29 AM Reply
The same thing happened to me with my head unit - I went with the 420bt which I could never go back from; the ability to easily tweak bass, low-mid, mid, and treble independently at each speaker is amazing.
There is an issue though and I'm planning to rectify it this season. The output from BT or Aux cord directly from a smartphone is unprocessed making the sound a bit harsh to listen to. I am planning to buy a receiver as an input to the 420bt just to process the sound before it gets amplified.
Old     (Gotmods)      Join Date: Nov 2012       02-24-2017, 8:49 AM Reply
Do any of the bt units process the sound from the smart phone? Looking at the rocker switch that might be the way I go since I have a spot for it.
Old     (chpthril)      Join Date: Oct 2007       02-24-2017, 9:43 AM Reply
@brad,
Im sure you already have, but make sure your phones internal EQ settings are flat or off. Nothing makes blue tooth to a full range system sound like @$$, faster than the phones EQ settings.
