you can fit the 2010 boots with the standard '10 baseplate but will limit the widest stance for the 8" hole pattern, basically by an inch or two. To get the widest stance possible, i'm pretty sure you can use an 09 baseplate that will fit equally well on the '10 boots. ask your local shop if they have any spare 09 plates, they should be able to swap you out.
