Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through February 15, 2009
Old     (doug2)      Join Date: Jan 2004       02-10-2009, 1:14 PM Reply
2005 Boatmate trailer. Might have a short or bad wire and some bad weather moving in. Any way to physically lock it out?
Old     (dhcomp)      Join Date: Jun 2003       02-10-2009, 1:32 PM Reply
Look at the where the tounge slides, and put something in its way. There is a slot on teh side of the coupler, and you should be able to jam a male garden hose fitting or something in there to keep it from sliding.
Old     (doug2)      Join Date: Jan 2004       02-10-2009, 1:41 PM Reply
Thinking along the same lines. Maybe a c-clamp?
Old     (wake1823)      Join Date: Dec 2005       02-10-2009, 2:33 PM Reply
I've used a quater, taped in there.
Old     (tdiggity)      Join Date: Dec 2006       02-11-2009, 8:43 AM Reply
5/8" head bolt or nut and some electrical tape works like a champ
Old    Slingshot            02-11-2009, 10:09 AM Reply
Make sure its not the tow vehicle. Send 12 volts to the blue wire and ground the white wire on the trailer. That will unlock the brakes if everything is working right.
Old     (topside_marine)      Join Date: Sep 2005       02-12-2009, 10:54 AM Reply
Most trailer actuators have a mechanical lockout device for disk. Call the manufacturer of the trailer and they should be able to help. If not you can call me and I will help you find the right solution. I have a few different types in stock but without the type of actuator I wont know what will fit.
408 451 9596
Old     (doug2)      Join Date: Jan 2004       02-12-2009, 11:39 AM Reply
Thanks for the replies. It was the vehicle wiring.
