Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through August 19, 2008
Old     (eyekahn)      Join Date: Aug 2007       08-13-2008, 6:14 AM Reply
My buddy nailed a log yesterday and we dont feel like taking it to a shop. I am very mechanically inclined. I tried to search to find a DIY but nothing. Anybody have any advise?
Old     (chpthril)      Join Date: Oct 2007       08-13-2008, 6:22 AM Reply
Buy or barrow a prop puller, 5 min job.
Old     (downfortheride)      Join Date: Jun 2005 Location: SLC, UT 5600'       08-13-2008, 6:27 AM Reply
All you need is the right tools. Get a prop puller and it will come off very easy, make sure to leave the nut on a couple of turns, the prop comes off with a big pop when it finally gives. Keep an eye out for the key (?) that is the metal piece that goes between the shaft and the prop, it's going to be about 2" long and a 1/8" thick square. You can also call a shop and they will probably offer to pull it real quick and you tell them your going to put the new prop on. This is where you will know the difference from a shop that is out to help with great customer service or make money!
Old     (eyekahn)      Join Date: Aug 2007       08-13-2008, 6:44 AM Reply
Thanks alot. I knew there had to be a prop pulling tool. Ive never had to change one. I figured its basic.
Old     (texastbird)      Join Date: May 2003       08-13-2008, 4:45 PM Reply
A gear puller works pretty well too. You can usually rent one from the auto parts store.
Old     (wake_upppp)      Join Date: Nov 2003       08-13-2008, 5:42 PM Reply
Make sure the new prop is seated all the way up the taper on the propshaft or you could have a vibration after installation.
