04-23-2006, 6:16 PM
I bought the Rival ballast system for my '05 21' XTi got things pretty planned out...but...the Malibu guys strongly recommend not going through the hull (bottom) instead, "we" have decided to have the through hull water inlet...go through the transom...just below the platform problem is that there just isn't enough room for the nice through hull scoop that came with the system and...only 3.5" of open space around the exhaust ...to mount a through hull I have found a 2" through hull, but am in need of a strainer all stainless wire mesh stainers taht I have found are way to small I need one that will fit in the 3.5" space and allow for a 2" through hull pipe any one got any ideas? here is one I like, but it is to big http://www.groco.net/06-Cat/GROCO-2006.htm thanks
04-23-2006, 6:42 PM
I don't see the right item on the web page. Is that the right link? My rival system is coming this week!
04-23-2006, 6:52 PM
looks the same it's the groco web site page 40 at the bottom....under strainers I was mistaken...it's a 1.5" pipe, not a 2"
04-23-2006, 7:00 PM
my Malibu dealer wants to be able to fiberglass the through hull in I agree with him he is also concerned about hoses running through the stringers or under the engine he says that he has seen alot of overheating issues and other issues arise from alot of aftermarket add-ons he wants me to install a ball valve just inside the through hull fitting...in case of an emergency...but there isn't much room but,in my book...he is the man so I am just trying to configure the system so that he is comfortable...and willing to cut the holes and do the fiberglass work the Tige guys said cut the hole under the driveshaft area ... but Malibu says that there is a double layer there and he wouldn't feel good about it so we are going to try to go out th eback the downside to out the transom is....I won't ever be able to upgrade to a power wedge (mine is manual) and you can only fill while sitting still....no biggie
04-23-2006, 7:02 PM
I think that the Tige guys are great guys and know what they are doing they just have never installed on an XTi perhaps not a 'BU at all....
04-23-2006, 8:03 PM
The Rival already comes with an electric gate valve, you shouldn't need a ball valve separate from that. My understanding is that if it breaks, it always stays shut - if not, then I would like to hear of someone's experience with that. Being a direct drive, you have a different problem. There is a perfect little spot in most V-drives right in front of the transmission and behind the gas tank to put the thru hull. You don't have to worry about overheating if you add another thru hull. I think you can get some overheating if you T off of the engine's intake. A lot of guys do that, and I've actually only heard of the overheating as a theory due to water starvation to the engine, not any actual occurrences.
04-23-2006, 8:23 PM
Here's my .02 The factory will always tell you not to drill any holes or change anything. My dealer told me initially that if I didn't buy the factory tower that it would void my hull warrantee if I put an aftermarket one on. It's easier for them if you do things their way. If you put the through hull in a logical place and don't drill through stringers, and keep the plumbing and wiring completely separate from the factory wiring and cooling system, there shouldn't be a problem. I would not want to go through the transom for both of the reasons you outline above. The only possible hull issue is that if you have a cored hull (you do) you should fill the area in between the hull and liner with epoxy around the fitting. Same goes for a PP paddle wheel. Most installers don't, btw, and they still work fine with no leaks. Goop on the 5200! It is only an hour or two more work to do it the correct way. I think that is what your dealer was referring to. There is a good description of how to do it in the literature that comes with the PP paddle wheel. As for Tige vs. Malibu, when it comes down to it, a boat is a boat is a boat. Sure, there are differences, but even my crazy Toyota is built just like the other makes. Like other things, it's pretty much all the same with the lights off;) Do you have a second through hull already? Quite often there is one with a T handle in the center of the boat, mine is near the tracking fins. I used that one for my ballast fill. You do not need a scupper type fitting, a mushroom fitting will flow just fine, the water is under pressure anyway. Any opening below the waterline will do. Absolutely, you should have a bronze ball valve on the other side of the through hull, that's no bs. You should be able to access it relatively quickly too. The rival system has a gate valve, but it is plastic. Nothing wrong with it but it was not designed to maintain watertight integrity for a seagoing craft. I may add one to my system but I would still want to be able to close the ball valve after filling. If you put the hole in the transom, can you get to this fitting quickly on that boat?
04-23-2006, 10:11 PM
I am converting the ice chest to a seat...making the seat area bigger than the chest area we dont use that ice chest...and I am putting a bag in the new area this will allow somewhat of a rapid access...but still will have to reach under the gas tank the advantage to a transom install is that little water could get in (in an emergency) if the boat were moving I'm somewhat overwhelmed by the install just 'cause I what it done right the "Bu" guys won't do the complete install so I am trying to lay everything out and just have them do the actual through the boat stuff they said that in front of the engine would be the best place as far as the hole goes....but worried that it would interfear with the paddle wheel and...there isn't a very good spot to mount the 4 pump manifold and switch thanks for comments
04-23-2006, 10:20 PM
Psyclone the scoop that came with the system..and the manifold are both 1.5" diameter I have been trying to keep with that diameter are you saying that a smaller opening will work? I do have 2 drain holes in the boat bottom 1 in the engine compartment, and the other not much farther away, near the factory ballast in the ski locker I just assumed that I needed to stay with the 1.5" in order for the suppy/demand ratio to work
04-24-2006, 6:31 AM
I think that they used that size because the smallest standard gate valve is 1.5" You have four 750 gph pumps, give or take, right? A 2000 gph pump has a 1" inlet, I think the 3800 gph has 1.125. It isn't rocket surgery, a 1" inlet should be fine. Either way, I would certainly try it before I would drill any new holes in my boat! I think you would be fine. I'd hook it up temporarily and test by running all pumps at once, make sure you've got good flow.
04-24-2006, 7:29 AM
Great advice from psyclone. I wouldn't put the pickup on the transom if you can possibly avoid it. You will lose one of the biggest advantages to a built-in system - filling underway / on plane. The 21 XTi is a little tight on room in the bilge, and that Rival manifold is pretty big, but I'd make every effort to avoid putting it up on the transom. I agree on the bronze emergency shutoff ball valve too - mandatory for a good system design. The cored hull is easy to deal with; just glass the exposed core or bathe it in 5200. Just don't put the scupper in a place that will disrupt flow past any paddlewheels or depth finder transducers, and you'll be fine. Post pics along the way! Good luck.
04-24-2006, 9:44 AM
thanks for all of the input I will get pics posted when I get that far
Thread Tools |
Display Modes |
Linear Mode
