06-06-2005, 6:20 PM
im looking for those bindings bolts that you screw into the board then cam lock down..ive seen them on a board but failed to see who made those cam lock bolts..who makes them? thank you
06-06-2005, 6:46 PM
The are the Liquid Force F.A.S.T system cams. The call them "Liquid Cams" later, Clay
06-06-2005, 6:48 PM
Wasn't there some called Lokz or something. I think they went under or sold.
06-06-2005, 8:05 PM
Liquid Force has licensed the technology from Lokz, but I'm not sure if Lokz makes them any more. I know that Liquid uses the design, but makes them themselves. Anyway, you should be able to get a set from your Liquid Force dealer.
06-06-2005, 8:16 PM
thank you..anyone know how long the screw is on the liquid cams? i need the screw to be at least 1" long to use with my NICE PSR1 Bindings....
06-06-2005, 8:22 PM
Just measured...3 1/3 centimeters of thread and the actual screw with the 2 supplied washers is just shy of 3/4". Hope this helped. Clay
06-06-2005, 8:34 PM
so the end of the screw to the washer is 3/4" long? ...argh i need it close to 1" long
06-06-2005, 8:37 PM
yes, the shank of the screw is a hair UNDER 3/4". I dont see what it has to be 1" long, you dont have to bottom the screws out. Now if the screws are too long then that would be a whole different story, but as long as you get at least 3 threads you should be good to go. Clay
06-06-2005, 8:46 PM
i tried to use a screw with the special counter sunk washer that was 3/4" long over all from end to washer..NICE PSR1 Bindings have a thick baseplate, exactly 1/2" thick..the Threads in my 2002 Hyperlite Project board dont start at the surface of the board maybe a good 1/8 inch below the surface of the board..what do you think?
06-06-2005, 8:48 PM
is that washer that comes with the "liquid cams" Allumiunum and thick? could you use a thinner nylon washer instead? to expose more thread?
06-06-2005, 8:48 PM
dave, just curious, how did lf improve the technology? i still have a pair of lokz and compared them...exactly the same.
06-06-2005, 8:52 PM
it is two thin nylon washers, im sure you could get by with one BUT it isnt going to give the 1"
06-06-2005, 8:54 PM
Joe: BY "liscensing the technology" Im pretty sure he wasnt implying they improved on them (very simple design) They just bought the technology and put their name on it.
06-06-2005, 9:01 PM
I don't know if LF has changed them at all. I'm assuming they are the same basic design, but I don't know for a fact. I just know that they licensed the idea because they thought it was a good one.
06-06-2005, 9:04 PM
im looking at a picture of the 2001 lokz and todays "liquid cams" they both look different..same design concept but the lokz have a trick bevelled alluminum washer..and they came in colors
06-06-2005, 9:05 PM
dave, am i high (not really) or didn't your original post say that lf improved the technology?
06-06-2005, 9:10 PM
You would be high...but they still may have despite your inebriated state.
06-06-2005, 9:24 PM
aluminum washer= .05$ Krylon= .97$
06-06-2005, 9:31 PM
are you being funny..no the lokz seamed to be annodized and even a different shape..the washer was machined and also annodized...anyways not sure if the "liquid cams" will work..does anyone know how thick the baseplate is on "liquid forces" bindings .. are they 1/2" thick then i think the "liquid cams" will work with my NICE PSR1's thank you
06-06-2005, 9:36 PM
"are you being funny" Most of the time I try....(gets the tape measure out again...) The baseplate on my 05 Transits are a hair under 1/2".
