Adan,
If this is a Malibu VLX, you need to measure the tower pod's OD and ID to see if it will fit a driver the Kicker KMS67, Ive some across those pods that would only accept a 6" speaker. Also, the Kicker KMS67 is a 4 pod setup.
To get the needed power for a pair of HLCD, you would likely need to bridge one of your 4 chnl amp. In most cases, those older explode amps will not run in 2 chnl mode and only have a fixed hi-pass. So no go for bridging a pair of tower speakers.
You need to prioritize your needs based on what equipment is toast and needs to be replaced and what zone is the most important. If getting wake range projection is a high priority, then focus most of the available budget to the tower zone, put plan ahead for the future upgrades.
