If you take a regular progressive edge the board will load along with the rope. As you pop off the top it will release and kick you. I've not ridden the Co. but have ridden the Slingshots. All you need to do is really emphasize your progressive edge and you will be fine. Thats the good/bad things about flex, if you have a good edging fundamentals it will work well, if not, you better learn it or the board will not work for you.
