For all the knowledge and information that I have gained on this website, I wanted to share my ballast install to help others. I bought the fly high kit for the X2. The kit included 3 custom sacs, 3 three way valves, 3 check valves/T adapters, 50 feet of hose, and hose clamps.
The first step and the most stressful step was drilling holes in the boat under the seats. I put the templates up and measured everything at least 4 times before I drilled. I then drilled a small pilot hole first. I then drilled the 1/4" holes for the screws and then the 3/4" hole for the valve. I ran the drill in reverse to start and that kept the gel coat from splintering. Here are the pics.
I had to take the handle off of the valves to install them. With the vavles in place, I went ahead and layed out the bags in their places. I started with the front. The basic concept is to run the discharge from the pump to the 3 way valve and the top discharge goes to the fly high bag and the bottom discharge goes to the factory hard tank. Here is a pic of the front pump and valve.
![Upload](http://www.wakeworld.com/MB/Discus/messages/65921/546150.jpg)
I just unplugged the hard tank line from the pump and hooked it to the 3 way valve. I then ran the line to the ballast going down the port side.
![Upload](http://www.wakeworld.com/MB/Discus/messages/65921/546151.jpg)
The next step was tying into the current vent with the check vavle/T combo. It was located under the dash coming from the front side. I then ran the line to the front to vent the sac.
![Upload](http://www.wakeworld.com/MB/Discus/messages/65921/546153.jpg)
That was it for the front. I then started with the port ballast. I had to acces the pump at the back of the boat in the locker. I then had to run the discharge of the pump to the 3 way valve and a line back to the hard tank. This wasn't hard, but it was a royal pain in the a$$.
![Upload](http://www.wakeworld.com/MB/Discus/messages/65921/546154.jpg)
I then ran a line from the 3 way valve to the bag by drilling a hole in the plastic divider where the line lined up with the sac.
![Upload](http://www.wakeworld.com/MB/Discus/messages/65921/546155.jpg)
I then cut the port vent and added the check valve/T.
At this point, I was out of hose. I couldn't believe that a turn key kit didn't have enough hose and I installed the valves and ran the lines as the directions showed, but that is for a different thread. I will finish the starboard side once I get the hose in, but it will be identical to the port side. The hardest part was unhooking and rehooking the line to the hard tank ballast. So far, I probably have 8 hours involved, but I spent most of that time drinking.
The last step was reprogramming my timers, which has proven difficult. One timer allows me to go up to 20 minutes and the other 2 allow me to go to 6 minutes. I figure I will need around 10-12 minutes to fill the hard tanks and the fly high bags. This will give me around 2500 in ballast and I am definatly looking forward to summer. I will keep you updated on the timer situation. Once again, I hope someone benifits from this, as I have benifited from the ballast install threads of the past.
