Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through April 21, 2006
Old     (bbeach)      Join Date: Jul 2002       03-22-2006, 8:40 AM Reply
I'm in the process of refurbishing my boat trailer at the moment! Thought I'd share some pics along the way!
This past weekend I stripped the trailer of all the fenders, lights, wiring, winch, bunks, etc. and have fabbed up some brackets for two 3 inch caster wheels for the prop cage. As well as welded on a new swing away tongue. (old tongue was a surge brake tongue)...
Trailer is currently being sandblasted and powdercoated... Hoping to get pics after thats done but before PC'ing...
Old     (yosquire)      Join Date: Jun 2005       03-22-2006, 8:56 AM Reply
Thanks for posting the pictures.. I love watching projects like this.
Where did you purchase the swing-away tongue?
Old     (bbeach)      Join Date: Jul 2002       03-22-2006, 9:21 AM Reply
The swing away tongue came as a kit for bolt on or weld on from Croft Trailer, in KC...
I'll post more pics as progess is made!
Old     (whitlock87)      Join Date: Feb 2005       03-22-2006, 9:43 AM Reply
Are you going to put brakes back on?
Old     (bbeach)      Join Date: Jul 2002       03-22-2006, 9:47 AM Reply
No on the brakes...
Old     (crowmobe540)      Join Date: Mar 2004       03-22-2006, 12:10 PM Reply
It looks like you are going to put rollers on the prop guard. Great idea! Mine work really well.
Old     (rodmcinnis)      Join Date: Sep 2002       03-23-2006, 11:21 AM Reply
three comments:
1) were you done with the welding of the new tongue? I would have expected a bead along the top and bottom, not just along the sides. It would be really bad to have that tongue tear off while you were going down the road.
2) Why no brakes? In some states brakes would be required and they are really a good idea.
3) I am not sure that the rollers are in a good spot or right hieght, but I am not quite visualizing it complete. It looks like the rollers are going to be near the center of the prop guard, and substantially lower. This will put a lot of stress on the center of the guard when the rollers get used. The last thing you want is for the prop gaurd to get bent up into the prop.
My trailer has rollers that are mounted on the vertial supports to the prop guard in such a way that the bottom of the roller is just below the level of the guard. Here, look at this picture: http://www.dhmtrailers.com/online/home.php?cat=161
This puts any load forces up into the trailer frame instead of creating bending forces in the middle of the guard.
Old     (bbeach)      Join Date: Jul 2002       03-23-2006, 11:40 AM Reply
1.) The tongue is bolted through with 2 grade 8 bolts as well as welded on each side and bottom. I'm not to concerned about it coming off...
2.) The previous owner removed the brakes 10 years ago because they took a lot of maintenance to keep them functioning. I've towed this boat probably 10k miles and never had the brakes and frankly never needed them. I considered putting them back on during this refurb but it didn't seem cost effective when I hardly tow the trailer more than 25 minutes at a time these days and I have a full size truck (and a 2500lb boat loaded)...
3.) The wheels will hang down far enough below the frame to handle a 45 degree angle... That is 1/4 inch steel stock welded top and bottom and the force on those caster wheels is relatively limited so I wasn't worried about them bending.
I'll post more pics when I get the wheels installed so you can see the finished product. Hoping it works fairly well...
Old     (bbeach)      Join Date: Jul 2002       03-27-2006, 8:49 AM Reply
After powder coating...
Top view of rear wheels installed.
a little dusty from sitting in RMI's parking lot but sharp with the gloss black powder coating.
I'll be re-finishing the fenders and re-installing this week as well as all new wiring, LED'S and new MC stickers with pinstriping...
enjoy!
(Message edited by bbeach on March 27, 2006)
Old     (99_slaunch)      Join Date: Oct 2005       03-27-2006, 2:13 PM Reply
Nice work!
Old     (ktmwakeboarder)      Join Date: Jun 2004       03-27-2006, 5:55 PM Reply
Sweet! Seems lke a very well thought out project :-)
Old     (yosquire)      Join Date: Jun 2005       03-27-2006, 7:40 PM Reply
looks good!
Old     (bbeach)      Join Date: Jul 2002       04-10-2006, 7:57 AM Reply
I've moved on to the fenders... Last year I broke the right fender on a rock at a launch and had to refiberglass it. Once these dry this week and really cure I'll be putting new custom stickers, pinstriping (on trailer) and new rubber pads on the fenders and then new wiring and all new LED's...Upload
fiberglassed back in the right tailight that was broken.
after sanding and puttying all the surfaces for a smooth finish
primered black and resanded
one coat of gloss black!
and another coat!
