Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through December 26, 2006
Old     (fill_er_up)      Join Date: May 2006       11-19-2006, 6:37 PM Reply
2000 Tige 21V Limited, Mercruiser 350 Magnum MPI. Getting vibration that rumbles through the hull while at idle speed. Not huge but definetly was not there beginning of the season. Happens at idle speed and also is evident when transmission is not engaged and I rev the engine at low speed but goes away once past that (prop not engaged when checking it this way, which is why I say not the prop). No visible shaking of the engine by the naked eye. Any obvious or not obvious reasons you can think of?
Old     (99_slaunch)      Join Date: Oct 2005       11-19-2006, 8:05 PM Reply
Does it do this when it's warm or cold? Not very common but I have seen harmonic balancer rings walk.
Old     (fill_er_up)      Join Date: May 2006       11-22-2006, 5:38 PM Reply
Warm or cold has no effect. The best description I can give is that I used to be able to idle around the lake with just a low purr from the engine and now I have to bump up my idling speed a bit to quiet down the sound and vibration (again, this is the same if the transmission is engaged or not). I did get some feedback to check the distributor cap, plugs and wires in case it is misfiring at low speeds. Any other feedback from the engine gurus?
Old     (sea_ray_dave)      Join Date: Dec 2004       11-22-2006, 6:00 PM Reply
I would say it is most likely somewhere in the ignition system. Plugs, wires, distributor cap and rotor can all cause these symptoms. IF there are oxygen sensors in the exhaust system, they can fail and cause false readings that will also cause a rough idle condition.
Old     (snyper1d)      Join Date: Mar 2005       11-22-2006, 9:08 PM Reply
Pull all spark plugs to see if all cylinders are hitting. Look for moisture (gas) on plugs, as well as burnt tips or carbon fouled plugs.
