Old     (MUNS)      Join Date: Jan 2012       05-21-2013, 11:16 AM Reply
So, went out on the water yesterday and did a little bit of riding. My boat is an 05 launch 21v. After i was done I started draining the bags, one of the pumps has always had draining issues ( it pumps well, then cuts out ) if i play with the switch or mess with the bag I can usually get it going again. But yesterday it cut out when the bag was nearly empty and I started smelling like something was burning.. so I checked all the fluids, engine oil, v drive oil and transmission oil, they were all good and full. The hoses running into the impeller were cold and the gauge said the engine temp was good as well.
When I had the boat home and in the driveway I was searching around to find the culprit of the smell. I started playing with the pump switches. When I hit fill for the right rear pump I can hear it come on, but when I hit empty I heard nothing. I hit the other switches to empty and could hear all of those come on.
I was under the impression that the pumps in my boat did both the drain and fill but maybe I am wrong? and would a burnt out pump give off a burning smell?
Old     (Dmac420sj)      Join Date: Mar 2012       05-21-2013, 11:46 AM Reply
Yes absolutely. I don't know about aerator pumps but a reversible will. Remove it and smell it.
Old     (jonblarc7)      Join Date: Jul 2006       05-21-2013, 12:19 PM Reply
O5 supra 21v will have one pump that fill all three bags and three pumps to empty each bag. It uses three irrigation valves on the fill pump to the direct the water to the right bags when your filling and a single pump a attached to each bag to empty. Sounds like you drain pump went out.
