Old     (spherren)      Join Date: Aug 2005       05-20-2007, 10:52 PM Reply
I just bought a 06 V-Ride 21ft this year. What is the difference between the V-Ride, VLX, and the VTX? If i put a lower pitch prop on would it help my hole shot? Thanks guys....
Old     (05mobiuslsv)      Join Date: Apr 2006       05-20-2007, 11:08 PM Reply
Vride is the vlx hull from 2004 and earlier. VLX has the new v25 wake hull and more ballast. The VTX is a new boat from malibu for 2007. It's basically a 20' version of the vlx. What prop do you have now, and what motor?
Old     (curtisco24)      Join Date: Dec 2005       05-21-2007, 6:48 AM Reply
Yes it will help go to the malibu crew . com and they can tell you exactly what prop to get.
Old     (auto)      Join Date: Aug 2002       05-21-2007, 7:00 AM Reply
Nu Bu is correct, V-Ride is great ride, was on one this weeked, great boat. If you are going to sack it out more than one in the walkway a different prop would help on bow rise/planing. The older VLX/New V-Rides need weight in front to properly shape wake and cut bow rise.
(Message edited by auto on May 21, 2007)
Old     (auto)      Join Date: Aug 2002       05-21-2007, 7:02 AM Reply
Pic of 03 VLX with one 500 in the center, front/rear full, wedge and 4 guys.Upload
Old     (spherren)      Join Date: Aug 2005       05-21-2007, 11:39 PM Reply
I have the 21ft V-ride with the 320hp 5.7l. Stock prop. Hoping for more bottom end.
Old     (05mobiuslsv)      Join Date: Apr 2006       05-22-2007, 2:14 AM Reply
Get the ACME 1235.
Old     (helinut)      Join Date: Apr 2007       05-22-2007, 10:13 AM Reply
I've read a bunch at the other site, and pretty much everyone says go with the ACME 1235. I don't even have my boat yet, but I'm thinking about getting one of those props for a spare.
Shawn
Old     (tracktor)      Join Date: Sep 2005       05-22-2007, 10:23 AM Reply
I've got an older VLX with a 320 monsoon. With the stock prop (14 x 18 4-blade) and 2k ballast it took awhile to get on plane. I put an OJ 475 on it and it comes up better now with ballast than it did before empty. It also runs much smoother. The OJ prop was alot heavier duty than the stock. Very impressive all around. I bought it through a group buy on themalibucrew.com............
Old     (05mobiuslsv)      Join Date: Apr 2006       05-22-2007, 11:30 AM Reply
The OJ 475 is the same as the ACME 1235, spec wise that is. The OJ is a little thicker prop and has more rounded blades than the ACME.
Old     (spherren)      Join Date: Aug 2005       05-28-2007, 12:52 PM Reply
What pich is the ACME 1235, or the OJ 475. diameter and pitch as per say a 13.5x16 1.5 is on my boat now.
Old     (05mobiuslsv)      Join Date: Apr 2006       05-28-2007, 1:02 PM Reply
The pitch is 14.5 and diameter is 14.25.
