Mike, Get with someone that know's how to do glass work if you dont, or get a book and learn how to do it. FiberGLASS does not flex it cracks. It happens around Tuna Tower mounts, windshield frames, cleats, motor mounts, tow points and yes - even wakeboard towers. It's not a huge deal and it can be easily fixed. I did tons of this when I was younger and you need to grind out the crack down to some glass, put some resin & chop in there to fill it back up, re-gelcoat with some color match, finish it out and go ride some more. You may want to lay up a few more layers of glass underneath during this under the deck for the front legs of the tower at the same time for some cheap insurance. Also, have you had people diving off your tower, this is way beyond what gelcoat can handle if you have a tower with fixed mounts. If so this is what caused the problem. Bill
