was wondering if shaft packing on a 2000 v-drive sunsetter is suppose to leak and if so how much, and how do you adjust it if need to .Any info would be much appriciated.
I have never done the adjustment, but I need to, this is what a BU tech told me. Best to do in the water. Loosen big top nut, hand tighten only inside nut til water drips in at 5 to 10ish drips per minute, then tighten down large locking nut.
The lock nut is the small one and the adjusting nut is the large nut at the end, back off the lock nut then turn packing nut by hand to get the correct drip count, tighten lock nut up to packing nut.
