Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through March 18, 2009
Old     (smuurph84)      Join Date: Oct 2008       03-15-2009, 5:47 AM Reply
I am in the process of adding the threesome setup but in todays economy I am going to have to do it in steps? I plan to purchase two pro 80s to start and I already have an amp. http://www.sonicelectronix.com/item_12207_Hifonics+ZXi+8408.html?utm_source=froog le&utm_medium=organic&utm_campaign=froogle
what would be the best way to wire the two pro 80s with it? my plan is to add a 485 and change the amp to a syn 6 in the fall? also should I go ahead and prewire my tower for the 485 any info would be great thanks
Old     (thesack)      Join Date: Mar 2008       03-16-2009, 10:04 AM Reply
Bridge your amp so that you have enough power running the Pro 80's (assuming you are meaning that your running 1 pair of Pro 80's not 2 pair).
Personally i would go a head and prewire your tower. That way when you are able to get the 485 and the new amp its a quick install.
Old     (wetsounds1)      Join Date: Jan 2006       03-16-2009, 10:18 AM Reply
murph,
For sure, run 3 pairs of wire up the tower so you are already set for the 485.
As for that amp, bridge it in 2 ch mode for the 80's and watch the gains as it will be a ton of power but you will be fine. Just make sure to tune it right.
Tim
Wet Sounds
