Old    david_fletcher            04-05-2003, 10:02 PM Reply
Delivery on 03 SAN Team Edition in 2 days (will post pics). After break in how is it best to weight it. How much front, back ect? If this is on another thread link it I could not find one.
Old    chase            04-06-2003, 4:47 AM Reply
We like it this way:
Factory Ballast, additional 300lbs in back, 300lbs in belly, and 300lbs in front. This seems to put out a big and steep wake. Good luck, I think you are going to love it!
Old    masonlakerider            04-06-2003, 11:35 PM Reply
What is each of your extra 300lbs in weight...Fat sacks/lead/other?
Old    chase            04-07-2003, 5:08 AM Reply
My boat is slightly different due to the smaller factory ballast, however, my buddy just got a 2003 Team and his additional weight is all lead. He has a tandem axle with disc brakes so trailering isn't a problem.
I use a combination of sacs and lead to acheive the same thing.
Here is a bad pic but a pic none the less:
wake
Old    boozcruz33            04-10-2003, 9:17 PM Reply
Lead is definitely the way to go. It is heavy and a pain to move around... but once it is settled, you never have to touch it again.
I currently have an 03 SAN with the wedge tanks, belly ballast, and 400 lbs of lead. We went out with about 5-6 adults last weekend and the wake was great!
I think I am going to pick up another 400-600 lbs of lead just in case we don't have that many people with us all the time. I just need to figure out the cheapest place to get the lead and the best place in the boat to put it. I would definitely recommend at least 60% of the additional weight in the bow of the boat.
Old     (pesos)      Join Date: Oct 2001 Location: Texas       04-10-2003, 9:28 PM Reply
i have 260 lbs of lead in the bow, 130 at the drivers feet, 65 right behind the drivers seat, and 65 on each side in the rear.
Old     (south30)      Join Date: Apr 2002       04-10-2003, 10:54 PM Reply
we run 250lb - in bow- (lead)
500-550 in ski locker(water)
stock ballas in back(flat tanks) + 500lb sack on top of each tank(water)
and i just got 250lb lead to go on the sides of the back seats--
ps. my friend and i only have a girls with us most the time- they only weight 100 or so each ,and we ride just him and i alot.... that why we ride with alot of weight..
not because we like a big wake---ya right
keep the weight com'en
Old     (wakejunky)      Join Date: Apr 2002       04-11-2003, 8:30 AM Reply
What size sacs are you using on top of your rear tanks and what type?
Just got the birth cert. for the new SAN, She'll be hull number 560 due in June.
Chris
No Slip Gator Grip
www.wakejunky.com
Looking for new home:
http://home.surewest.net/cfoye/96SportNautique/96SportNautique.htm
Old     (dees)      Join Date: Apr 2003       04-15-2003, 8:54 AM Reply
In our 03 Super Air we run:
Stock ballast: 820
4 Sand bags on each Wedge tank: 480 total
2 tractor wieghts rhino lined (one under very front seat 100lbs, one behind drive seat or moved where needed 100lbs): 200
1 Phat sac in bow: 350
Speaker box under radio: 50+
and 4 people.
I will get pics today when we go out.
Old     (cryptic22)      Join Date: Apr 2002       04-15-2003, 4:59 PM Reply
Full factory ballast. (2 rear wedge tanks, 1 center tank)
50 lbs lead behind drivers seat
2 – 250 lb fat sacs on top of tanks in back
1 – 700 lb fat sac in the center walkway
