Old     (j3t_m3ch)      Join Date: Jun 2006       04-20-2008, 1:35 PM Reply
Well...Today was depressing. We got to the water and the boat wouldn't start. The weird thing is, is that we started it right before we towed it. Everything was working fine. Right when I got the boat in the water the engine hatch wouldn't raise and the engine wouldn't even turn over(so the signal is getting there) I'm guessing its something electrical so I checked as many fuses as I could see and wires. Any rccomendations on where I should start? I just want to get in the water!!! Thanks
Old     (trdon)      Join Date: Sep 2007       04-20-2008, 2:00 PM Reply
clean the battery terminals, It will fix it 40% of the time. If not that, the starter solenoid or the battery itself. Start there as those are free3 :-)
Old    alanp            04-20-2008, 2:02 PM Reply
also check your circuit breakers(the little red buttons on the front of the engine). i think there is a 15, 60 and maybe a 30. push those. my boat does that from time to time
Old    K.B.C.            04-20-2008, 2:18 PM Reply
you try jumping it?
Old     (j3t_m3ch)      Join Date: Jun 2006       04-20-2008, 4:49 PM Reply
I will definately try those out. I kinda cancelled out the battery sinc we just had it running 10-15 min prior. My buddy has a charger so were going to try that too. Thanks alot and I'll post up when I figure it out......
Old     (j3t_m3ch)      Join Date: Jun 2006       04-29-2008, 8:46 AM Reply
The starting prob was the starter solenoid. Still haven't figured out the actuator problem though. Im guessing that one is wiring somewhere but the boat can go without that working!Thanks again for the help.
