Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through May 01, 2007
Old     (bltcollins)      Join Date: Feb 2007       04-27-2007, 6:40 PM Reply
I just bought a 4 channel amp to power 4 tower speakers and I just realized I have a stock stereo with a single preamp output. Can I just put a splitter on there? If so is this something I could purchase pretty readily at something like a radio shack, best buy, etc. I'll probably buy a new stereo but need a quick fix for a trip I'm taking next week. I can deal with just hooking up the two but if there is something quick and easy I can do then why not. Anyway, I appreciate the help and any other suggestions.
Old     (newty)      Join Date: May 2005       04-27-2007, 6:50 PM Reply
Your amp should take a single pre-amp to feed 4 channels if you don't have 2 deck pre-outs.
pretty standard on most amps.
Old     (bltcollins)      Join Date: Feb 2007       04-27-2007, 6:52 PM Reply
Something like this maybe...am I making this harder this then it needs to be. Have only hooked up one amp before and it was very straight forward. Thanks
http://www.radioshack.com/product/index.jsp?productId=2117929&cp=2032059.2032325.203 2326&allCount=94&fbn=Type%2FAudio+Cable&f=PAD%2FPr oduct+Type%2FAudio+Cable&fbc=1&parentPage=family
Old     (bltcollins)      Join Date: Feb 2007       04-27-2007, 6:55 PM Reply
Thanks Newty didn't see your response before I posted again. I'll check that out...of course I didn't even check the amp for something as simple as that. Just assumed I would have to rig something. My bad.
Old     (newty)      Join Date: May 2005       04-27-2007, 7:01 PM Reply
NP
Old     (bltcollins)      Join Date: Feb 2007       04-28-2007, 9:25 AM Reply
O.K. I checked the amp and it has two inputs, one for the 1/2 channels and one for the 3/4 channels. When I hooked up the first on my old amp the 3/4 speakers didn't have any sound until I connected an additional cable into the 3/4 input. Is there just a switch or something to tell the amp I only have the one input? This amp is a pretty cheap crunch amp but I don't have a couple grand, or even a few hundred right now, to sink into the system so it will have to do. The 4 page manual is a joke and doesn't give much direction.
The amp does have basic speaker wire (high level) inputs that I can just connect the speaker wires from the head unit to. Will this sound o.k. Seems like a pretty cheesy way of hooking the speakers up but if the sound is the same as the audio cable then I'm good.
I guess my question is what would you guys suggest. I would like to have the capability to fade so seems like using the high level or some combination of the two, still need to power a couple 6 1/2s in the boat, is my best bet but if it's going to seriously degrade the quality then I can live without the ability to fade between front and back speakers. Basically I have a set of tower speakers that are front/back. Anyway, I appreciate any suggestions. Thanks.
Old     (mikeski)      Join Date: Aug 2003       04-28-2007, 12:54 PM Reply
I would add an EQ. I didn't the first time around and went back later. There are cheap enough units out there. For just a few more bucks then some Y's it's a good investment.
http://cgi.ebay.com/CLARION-7-BAND-EQ-EQUALIZER-1-2-DIN-GRAPHIC-CROSSOVER_W0QQitemZ320108450877QQihZ011QQcategoryZ 79841QQrdZ1QQcmdZViewItem
http://cgi.ebay.com/SoundStream-MPQ-6XO-4-Band-Parametric-EQ-Sub-Output-NEW_W0QQitemZ150114065828QQihZ005QQcategoryZ79841Q QssPageNameZWDVWQQrdZ1QQcmdZViewItem
http://cgi.ebay.com/MBacoustics-PARAMETRIC-CROSSOVER-EQUALIZER-PEQ-401_W0QQitemZ290109848604QQihZ019QQcategoryZ79840Q QssPageNameZWDVWQQrdZ1QQcmdZViewItem
http://cgi.ebay.com/MA-AUDIO-MPE200-4-BAND-VARIABLE-PARAMETRIC-EQ-EQUALIZER_W0QQitemZ300104780655QQihZ020QQcategoryZ 79840QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
