Old     (pottsy)      Join Date: Jul 2006       08-24-2006, 8:05 PM Reply
hey guys, i havent been riding long but ive progressed quite a bit so im gonna start with some inverts.... im gonna go with the backroll as my first, but i really have no idea how to execute it so if anyone would be kind enough to give me a description of it that would be great. Thanks
Old    alanp            08-24-2006, 8:34 PM Reply
try searching this, it has been discussed a ton of times. you actually dont even need to search just scroll down on the trick tips section. if after reading the many threads on the backroll you still have questions, post a question. sorry im not attacking you, but with a little work you can probably dig up enough info to get you going.
Old     (big_xstar)      Join Date: Nov 2004       08-25-2006, 2:30 PM Reply
go the WW home page and look at the left column and wake tricks 101 ..Instrutionals. there a ton of video clips you can watch for help.
My own input.. dont have to cut our far, get a nice good hard edge, dont just crank in with speed. Get alot of load on the line. As you approach the wake maintain your edge and line tension all the way up thru the wake, stand tall as you leave the wake and stay on edge then look over your lead shoulder which will begin your rotation. keep your hands on the handle all the way thru the trick. Continue to look over the same shoulder to spot your landing as you come around. the rest is gravy...
Good luck...
