Old     (ladythump)      Join Date: Jul 2004       04-06-2005, 6:57 AM Reply
Ideally I'd like to angle my sub up against the side of the boat. Any ideas how to attach? Here's a pic:
Old     (clubmyke)      Join Date: Aug 2004       04-06-2005, 7:21 AM Reply
i would try it there before you do mount it...
i didnt have much luck with a side firing sub in my cc 211....there was a lot of cancellation and side wall rattle.
would suggest firng the sub front/back, i have heard it in a couple of installs and is sounds a lot better...
Old     (mikeski)      Join Date: Aug 2003       04-06-2005, 11:24 PM Reply
Cut a hole in the carpet and put a big blob of Silicone II on the sub then set in place trying not to move it until it dries overnight (looks like you could put a tire chock under it).
Old     (882001)      Join Date: Nov 2003       04-07-2005, 2:23 PM Reply
just run sheetrock screws from the outside.
Old     (cyclonecj)      Join Date: Jul 2001       04-07-2005, 2:45 PM Reply
Cut out the carpet behind where you want to mount the sub, glue a piece of MDF up there with Liquid Nails. When it's dry, mount the sub box with a couple of short screws from the inside (you'll have to pull the speaker out to do it) then put the speaker back in.
Old    whitechocolate            04-07-2005, 2:56 PM Reply
882001 :just run sheetrock screws from the outside.
Old     (timmy)      Join Date: Jul 2001       04-07-2005, 2:59 PM Reply
is your arm on the floor? just attach a couple wedge shaped pieces of wood to the bottom of the box and fasten them to the floor. this would be the least invasive method.
Old     (rvh3)      Join Date: Jul 2003       04-08-2005, 5:27 AM Reply
After you tighten the sheetrock screws, put some tape on the heads of the screws to hide them and slow any leaks.
Old     (882001)      Join Date: Nov 2003       04-08-2005, 8:10 PM Reply
or silicone close to hull color
