And my PPI 4125 decided to take a break
LOL
My Amp after 10 years of "Doing Work" decided it had had enough. A small puff of smoke and she fell silent. So I did some asking around on DIYaudio.com and it turns out their is quite a few guys that still repair these old amp's and "Mod" them in the process. I found a guy that will go threw my amp and fix whats broken and then Update it and Crank it up!!!! As if I needed more volume. He say's that replacement parts are quite common and much better than the originals. Most of the stuff that breaks can be replaced with better parts. Here are some pic's of the Dammage
The Frist 2 are of the Tower amp that smoked.
The 2nd 2 are of the Hull amp (Still working fine) But I figured I would get it cleaned up and tuned up and overhauled at the same time.
They will bench test it and set it to factory spec's or better and provide a output data sheet
