Old    smwakeboarder            05-08-2003, 9:24 PM Reply
anybody else wakeboard behind a ski centurion. I have a falcon w/ a crappy wake. Anybody else have one, wondering if i can weigh it down enough to give it a good wake
Old     (wakinwestcoast)      Join Date: Jan 2003       05-08-2003, 9:55 PM Reply
i used to have one. it is really hard to get a wake. but if you put 600 on each side of the engine and 600 in the bow and then get a good lad of people in the boat then you will get an ok wake. good luck.
Old    mmascari            05-09-2003, 8:34 AM Reply
I had one for the past two years, a 1998 Sport Bowrider. Sold it last July. The wake had absolutely no pop whatsoever. I ended up selling it to my brother, and occasionally I still ride behind it. I've had as much as 600lbs on each side of engine, 300lbs in back, and 350lbs in bow. It was scary to drive because it sat really low in the water and you have to be really careful not to dip the bow. It is still a good boat to learn. You just have to work a little harder to clear the wake.
Old    big_kahuna            05-09-2003, 9:05 AM Reply
hey andy I had a falcon for 4 years. Your right crappy wake and I tried alot ballast in bow and rear still sucked.the best wake I had was to 350 twins on the side of motor and a 500 in rear. Then it had a decent wake but the boat turned into a slug.Not much more you can do!
