Originally Posted by NuBu
I'm hoping it's just clogged. Only 260 hours on the boat, should the pumps be failing that fast?
The aerator pumps will last quite a long time assuming nothing gets sucked up into the impeller system. There is no strainer to remove debris being sucked in from the bottom thru-hull. Depending on your water conditions (sandy, merky, mossy, etc..) could affect the longevity of the pump.
The Piranha 800's are simple to replace, remove one phillips screw on top of pump and unscrew pump unit and replace with a new one. Takes about 5 minutes tops.
