Old     (Shooter)      Join Date: Apr 2010       05-24-2010, 4:48 PM Reply
I hooked up the fake-a-lake and tried to give the boat its first start of the season. After a minor battery issue, the boat appeares to be working fine except it wont start. Starter, bells and engine sound and turn normal.
Its been sitting for about six months in a garage. Freezing is not a issue. I also put some sta-bil in the fuel before storing it. Any suggestions of where I should start?
Old     (Shooter)      Join Date: Apr 2010       05-24-2010, 5:20 PM Reply
The engine turns over no problem, so the starter / battery sound like they are working well. It just wont ignite. How do I know if the kill switch is working? Maybe bad fuel?
BTW, it has always started quickly before today.
Old     (99_slaunch)      Join Date: Oct 2005       05-24-2010, 5:32 PM Reply
You need to check and see if you are getting spark.
Old     (bill_airjunky)      Join Date: Apr 2002       05-24-2010, 5:37 PM Reply
And is there fuel in the carb/EFI?
If the kill switch is pulled, then the engine won't turn over.
Old     (wake_upppp)      Join Date: Nov 2003       05-24-2010, 5:52 PM Reply
Yep check the basics. Fuel, spark and air, then go from there.
Old     (tyler97217)      Join Date: Aug 2004       05-24-2010, 6:24 PM Reply
as stated above make sure you check the kill switch lanyard
Old     (humboldtboarder)      Join Date: Sep 2005       05-24-2010, 7:02 PM Reply
I had the exact same issue about a month ago. Boat ran fine when it was put away, then wouldn't start when I pulled it out of the garage. Ended up being a bad fuel pump. The pump was running, but wouldn't make enough pressure.
Old     (mc_x15)      Join Date: Jul 2008       05-25-2010, 5:26 AM Reply
Kill switch?? Had a similiar problem.
Old     (cla10beck)      Join Date: Dec 2007       05-25-2010, 6:09 AM Reply
Mine has a fuel shutoff valve on top of the gas tank. Make sure that is open
Old    malibu_nut            05-25-2010, 6:28 AM Reply
did you run it after you put stabil in it? if not the fuel in the lines and carb/throttlebody/whatever fuel dilivery system you have, did not get treated it could very well be plugged up somewhere.
Old     (wtrgrl)      Join Date: Mar 2009       05-25-2010, 7:27 AM Reply
If you have a mechanical fuel pump it needs to be primed.
Old     (justintime)      Join Date: Mar 2009       05-25-2010, 5:20 PM Reply
what motor and year
