Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through September 22, 2008
Old     (kevfran99)      Join Date: Aug 2008       09-11-2008, 12:33 PM Reply
Here's my problem. It feels like I'm getting pretty good pop, but I can't make it all the way wake to wake. I seem to either make it pretty high(about 5-6' high) and land 2/3 the way across or I go farther (3/4 the way wake to wake) with much less air. How can I get the right air and still make it wake to wake. I'm doing everything I feel is correct. Cutting into the wake pretty hard and standing up from a seated position when I hit the wake with out flattening out my board. What suggestions do you guys have???? THANKS!
Old     (glee22)      Join Date: Jun 2008       09-11-2008, 12:51 PM Reply
how fast do you ride and whats your rope length?
Old     (tcaz)      Join Date: Aug 2008       09-11-2008, 12:56 PM Reply
hold your edge a little longer through the wake, and stand tall at the peek.
and as grant said, speed/rope length?
Old     (kevfran99)      Join Date: Aug 2008       09-11-2008, 1:11 PM Reply
speed is usually between 18-20mph rope is 75feet I believe. I seem to think the rope is too long. maybe it's just in my head.
Old     (element8456)      Join Date: Feb 2008       09-11-2008, 1:13 PM Reply
If your having trouble with crossing the wake shortening the rope up to 70' or use the progesive edge start out soft then harder still having trouble got to www.waketrix.com
Old     (element8456)      Join Date: Feb 2008       09-11-2008, 1:14 PM Reply
I learned how to jump the wake at 65' now ride 75'
Old     (polarbill)      Join Date: Jun 2003       09-11-2008, 1:18 PM Reply
That is too long of a rope for 18-20 mph. Shorten the rope to 65-70.
Old     (glee22)      Join Date: Jun 2008       09-11-2008, 1:20 PM Reply
ya you might want to pull the rope in to about 70 or 65 and keep it in the 20's
Old     (kevfran99)      Join Date: Aug 2008       09-11-2008, 1:24 PM Reply
Thanks guys. I will try shortening the rope tomorrow and report back with my progress.
Old     (tribute)      Join Date: Sep 2008       09-11-2008, 1:47 PM Reply
Also you could speed up a little like to 22. if you see the wake folding over then you know your going too slow. try speeding up and if you feel like your going to fast or your not in control then slow down again, but sometimes speeding up gives you the confidence you need to clear the wake
Old     (kevfran99)      Join Date: Aug 2008       09-13-2008, 7:10 AM Reply
shortened the rope to 65 feet and sped up to 20mph (which seems to give me the best wake on my boat) and I cleared it pretty easily! THANKS GUYS! Now on to more tricks!
Old     (helix_rider)      Join Date: Mar 2003       09-13-2008, 9:48 AM Reply
Good job...just make sure you don't become a heelside hero. When I was learning and got my first W2W, I was so pumped that I just kept doing that over and over again...but I never bothered toeside or switch because I couldn't clear the wake that way. Eventually, I had to go back to the beginning with those aspect and let's just say it's easier to learn it all at the same time instead of taking remedial sets to become more balanced.
Old     (kevfran99)      Join Date: Aug 2008       09-13-2008, 10:30 AM Reply
I worked a lot yesterday on toe side also once I started landing W2W consistently. Switch will probably start in the next two weeks. I want to land the toe W2W first!
