Old     (t8rtot)      Join Date: Apr 2008       05-06-2009, 5:30 AM Reply
ok so i have been trying the backroll and i thinki i'm almost there...after that i'm gonna try some tantrum...what do you guys reccomend next?
Old     (liquidmx)      Join Date: Jun 2005       05-06-2009, 8:05 AM Reply
Do you have all your 180's yet? That would be a good place to start is with all the basic 180's listed below.
HS W2W FS 180
TS W2W FS 180
Cab HS W2W FS 180
HS W2W BS 180
Old     (t8rtot)      Join Date: Apr 2008       05-06-2009, 10:16 AM Reply
yea i have ts and hs fs180's basically i want some new tricks such as spins, grabs, inverts that look good or even some inverts/spins with grabs...haha just anything
Old     (killercam)      Join Date: May 2009       05-06-2009, 11:35 AM Reply
If you have your TS jumps down, you can try some TS rolls. HS 3's are pretty easy to learn also.
Old     (t8rtot)      Join Date: Apr 2008       05-06-2009, 5:23 PM Reply
yea i'm gonna try to get some 3's....what ts inverts do you recommend?
Old     (liquidmx)      Join Date: Jun 2005       05-07-2009, 7:50 AM Reply
If your TS is good you could try a TS frontroll. Its similar to the HS tantrum with the tripping effect only a front flip instead of backflip.
You could also try a TS backroll, kind of similar to a HS backroll only the axis is a bit different and more of a straight up backflip than a cartwheel. Here is a link to an instructional:
http://www.wakeworld.com/Tricklist/TrickTip007.asp
Overall I would get all your basics down including switch if possible. If all your basics are on lock (including grabbed 180's) the more difficult stuff will come really easy and fast.
BTW one of the sickest basic tricks IMHO is a HS Method FS 180 and/or a TS poked stalefish FS 180.
Old     (t8rtot)      Join Date: Apr 2008       05-08-2009, 11:04 AM Reply
ok i'll look into those...i wish i could get some switch w2w's down toeside and heelside but i just get off balance every time. also how do you grab method again? that method 180 sounds really cool
Old     (liquidmx)      Join Date: Jun 2005       05-08-2009, 11:43 AM Reply
Method is your lead hand, melon grabbed with the board twisted a bit. Here is a link to the instruction for the grab from another site.
http://www.wakeboarder.com/tricks/methodgrab.phtml
