Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through June 20, 2007
Old     (sskitebabe)      Join Date: May 2007       06-04-2007, 2:43 PM Reply
I just bought a pair of ronix rise boots, and my big toes are touching when I stand up straight (in the house). If I flex the boot, my toes don't touch anymore. So, is that a snug perfect fit or a too small fit?
I ordered them online and can't return them once I get them wet, so I'd love some input from someone who owns closed toed boots!
Thanks, Liz
Old     (nwsjake10)      Join Date: Feb 2007       06-04-2007, 2:50 PM Reply
its definitly going to be hard to tell if you've yet to actually RIDE the bindings, i would say if your toes aren't CRUNCHED inside the binding, and are just a snug fit, you should be okay..if not..see if you can resell them on ebay or something??
Old     (sskitebabe)      Join Date: May 2007       06-04-2007, 2:55 PM Reply
I can return them now, since I haven't ridden them yet:-)
No, my toes aren't crunched, my big toe is just touching. Is that normal??
Old     (shredsickgnar)      Join Date: Sep 2006       06-04-2007, 2:56 PM Reply
I ride hyperlite murrays and all my toes are right up against the end. They are a perfect fit. Sounds like yours fit just right.
Old     (nwsjake10)      Join Date: Feb 2007       06-04-2007, 2:57 PM Reply
if its JUST your big toe, you should be fine, but if you ride them consistently and you lose feeling in your feet, i'd probably go with something alittle bigger..
Old     (ronnyboy27)      Join Date: Nov 2005       06-04-2007, 3:05 PM Reply
Most open toed binding stretch after you've ridden them a while, is it the same with closed toed?
Old     (airagain)      Join Date: Jun 2006       06-04-2007, 3:31 PM Reply
Hey Liz,
I have the Ronix Ones and had the same fear when I first got them. Just make sure you use the toe cap when they heat the boots. I don't even notice anymore.
Old     (sskitebabe)      Join Date: May 2007       06-04-2007, 6:16 PM Reply
Air Again,
what is the toe cap? I couldn't find them in any local shop, so I'm not sure I'll be able to have them heated.
Old     (nickdakoolkat)      Join Date: Sep 2005       06-04-2007, 6:42 PM Reply
so you have to heat the Ronix ones?
Old     (wake4chicks)      Join Date: Oct 2006       06-04-2007, 7:09 PM Reply
ur toes are supose to touch a little. when u bend ur knees they slide away. i bought rinix ones ad my toes touch a little. the lady at perf/ski said that they will touch a little and dont freak if they do.
Old     (auto)      Join Date: Aug 2002       06-04-2007, 7:14 PM Reply
Yep touch a little bit, and use the toe caps while heating. It does not seem normal, but the advice is correct, I listened to the WSA pro shop team and have been very happy.
Old     (sskitebabe)      Join Date: May 2007       06-04-2007, 8:13 PM Reply
ok, thanks! but, what are the toe caps?
Old     (airagain)      Join Date: Jun 2006       06-04-2007, 8:23 PM Reply
Liz,
The toe caps are a plastic piece that the shop should have to put over your toes to create a little more space when they heat the boots. I am willing to bet that a good ski shop that handles snowboard boots would have them as well. Best bet would be to go to a local shop that handles Ronix and have them do it.
Old     (sskitebabe)      Join Date: May 2007       06-04-2007, 8:36 PM Reply
Thanks for all the info!! I'll check out a local shop.
