Thought I might get some advice from you guys. I understand I wont get a huge wave out off my Calabria Cal-Air DD, but want to try and maximize it. Here is what I have: 700lb under floor Pure Vert Ballast, 350 lb to each side. Should I only fill surf side? A really big storage trunk in rear- thought I could put a 300-400lb bag in there, but it would go across the back of the boat. Is it better to run this all the way across or get a smaller bag in locker on surf side corner? A 500 lb lounge chair to run on surf side of boat from rear bench next to DD engine box. I have heard people mention a better side to surf on based on which way prop turns? How do you know which is stronger? Any other suggestions? Thanks! dg
