Old     (joshuag)      Join Date: Feb 2007       05-11-2007, 7:40 AM Reply
I finally started to get my wake surf wake dialed in. Port side wake (left side) is perfect. Strbd side needs a little more work. Anyways what i have noticed is that the wake sweet spot is really close to the swim step and would like to get that sweet spot pushed out a little more. By pushing the sweet spot back a little it would give me a little more room instead of running into the back of the boat. I hope that makes sence. If i need to get some pics to help i might be able to get some this weekend. Thanks
Josh
Old    surfdad            05-11-2007, 8:02 AM Reply
Two methods. Go faster :-) and/or shift weight forward. Try speeding up the boat first, see how that affects the size, length and shape of the wake.
Old     (surfnfury65)      Join Date: Aug 2004       05-11-2007, 12:32 PM Reply
I added a fat sac under the seat, either port or starboard, and it made a much longer wake.
Surf More/Work Less!
Wadd$
Old     (joshuag)      Join Date: Feb 2007       05-16-2007, 6:38 PM Reply
So I should try and put more weight up front? I am going to get the additional ballast for my boat within the next 2-3 weeks so that should help i think. I have been surfing at 11.5mph. Does that sound like a good speed or too slow? Thanks for the help.
Josh
Old     (jusstty)      Join Date: Dec 2006       05-16-2007, 6:47 PM Reply
More weight in the bow. Makes the wake smaller but longer.
Old     (bigshow)      Join Date: Feb 2005       05-16-2007, 8:45 PM Reply
IMO longer is much better than taller.
Old     (joshuag)      Join Date: Feb 2007       05-16-2007, 11:30 PM Reply
I have another question also. The left side of the wake is much cleaner and it actually curls like a real wave but the right side doesn't get as clean. A little bit of whitewash. Same amount of weight (people, ballast). Is that normall for some boats? Am i going to have to add alot of weight to get it clean? I will give more weight up front a try and let you know how it comes out. Thanks alot for the help
Josh
Old     (nauty_tique)      Join Date: Nov 2005       05-17-2007, 6:12 AM Reply
I would assume the wash on starboard side is due to prop rotation depending on the boat.
Old     (bigshow)      Join Date: Feb 2005       05-17-2007, 7:30 AM Reply
Right, the prop rotation makes it more difficult to make a good wake on one side or the other. It's less of an issue with some hulls.
Old     (joshuag)      Join Date: Feb 2007       05-17-2007, 3:25 PM Reply
How much weight do you guys put in your boat to get a good wake surf wake? I have an 06 X15 if that makes a difference
Old     (bigshow)      Join Date: Feb 2005       05-17-2007, 3:48 PM Reply
2,200 pounds. I'd love to see an X15 surf wake.
Old     (joshuag)      Join Date: Feb 2007       05-17-2007, 10:44 PM Reply
I will try and take some pics tommorrow or saturday for you. Then you guys can help me dial in my wake.
Josh
