need some help my board has a ding on the tip and its slowly getting bigger, any tips on how to fix it, or is there anything i can just pick up at a store to fix it. thx
if you want to fix it you will need a small drill bit and some epoxy. you just drill the hole a little bigger and then pull the top or bottom sheet back (just enough to pore it in) and mix the epoxy and then pore the stuff in and then take some tape and and put it over the hole so it will put the board back in the regular shape and then when you take the tape off you might have to sand just a little but not if you put the tape over the epoxy right
