Old     (drilldaddy78)      Join Date: Jul 2007       05-17-2009, 2:53 PM Reply
HEres the deal. 03 V230 When I put the boat in gear and come to speed slowly there is no problem. If I try to hit the throttle semi hard like to pull up a rider the rpm shoots up and it seems as though its slipping. I had the seat off and listened while someone else drove the boat and it sounds like a gear slipping. Is there a coupling or bearing that could have spun or does it sound more like I need to change the clutch? I have checked the linkage and it is adjusted fine/ Any help or info will be greatly appreciated.
Old     (1boarder_kevin)      Join Date: Mar 2007       05-17-2009, 3:15 PM Reply
check your trans oil level. if the level gets low, the plate will have trouble staying engaged. Other than that I don't know.
Old     (drilldaddy78)      Join Date: Jul 2007       05-18-2009, 12:36 PM Reply
Fluid level is ok. Its a little dirty tho. Is there a filter I need to change?
