Yes, you unscrew the bracket on the back of the speedometer and then pull the speedometer out from the front of the dash. It's been a while, but if I remember correctly there are 3 wires? One from the paddle wheel for speed, one for the light, and then a ground. Not sure if you will need to use any of these for the Stargazer? I wouldn't imagine that you would need the speedo wire, but you may need the light and the ground? You can call Perfect Pass and ask them. They should be able to help you.
