Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through July 28, 2004
Old    shanny            07-07-2004, 8:26 PM Reply
what are the worst-best wakeboard cores(ex.foam core, C.A.P.T)?
Old    icangetup            07-07-2004, 8:53 PM Reply
Well usually standard cores are heavier and more durable, but higher end cores are typically lighter, a lot more flexible and thus less durable.
(Message edited by icangetup on July 07, 2004)
Old    shanny            07-08-2004, 12:01 PM Reply
but like is foam or C.A.P.T a good core or like compression moulded fiberglass?
Old     (stephan)      Join Date: Nov 2002       07-08-2004, 5:28 PM Reply
Adam, you've got them all confused. My board is a foam core, has CAPT & is made with a process using compression molding of the fiberglass. It's called a CWB. There are only a few cores, foam, aluminum honeycomb, balsa, there are also some that have fiberglass rods or pre-impregnated carbon sheeting for stiffness. CAPT is CWB's process of dishing out area to reduce swing weight, they remove material while keeping enough for strength. Most all wakeboards use compression molding. Basically the process involves hand laying resin soaked fiberglass matting on the core and then applying pressure in a mold so that it conforms to the contours of the board. If you have any other questions let me know.
Old    shanny            07-08-2004, 10:58 PM Reply
i have a CWB Freedom and how good are their cores compared to others?
Old     (stephan)      Join Date: Nov 2002       07-09-2004, 9:59 AM Reply
It's a basic foam core, the foam is very dense & basically a stock core that has been tried & trued over the years. I have the newer version of your board, the Absolute, it has the exact same foam core as yours. Foam cores are known to be stronger than others but supposedly don't pop as much, this is because they don't have the quick recoil of a carbon rod or whatever. Just wondering, what's the core obsession about?
Old    shanny            07-12-2004, 8:00 PM Reply
no obbsession just wondering
Old     (schmaltz)      Join Date: Mar 2003       07-12-2004, 8:26 PM Reply
A good core has a high shear factor/closed cell yet porous for good bonding. The best cores in my opinion are CNC machined not poured. The further the glass is from the top sheet to the bottom the stiffness goes up exponentially same with groves or channels in the deck. Carbon rods wear down the foam core when it is flexed over and over, wearing away and eventually doing nothing.
