Old     (ryand121)      Join Date: Feb 2007       02-15-2007, 5:57 PM Reply
Would a RockfordFosgate Power T5002, have enough juice to run these two speakers pods. I appreciate any help
Old     (mikeski)      Join Date: Aug 2003       02-15-2007, 6:10 PM Reply
Probably, but my buddies RF amps powering his Def Vs and it shuts off from overheating (not a T5002).
If you have it run it in a well ventilated upright or end up mounting. If not I might recommend a Pioneer PRS-D2000T. It uses the highly efficient (less battery, less heat) ICE Power Class D full range chipset and pushes 300w X 2 into 2 ohms. They are fairly inexpensive and readily available.
Old     (clubmyke)      Join Date: Aug 2004       02-16-2007, 5:52 AM Reply
the rockford amp you mentioned is 75 watts rms into 4 ohms and 500 into 2 ohms mono...no again...
you will need at least 250 rms per side of high quality amplifaction (arc, zapco, tru etc..)
a arc xxk2500, zapco 1000/4(rewire the speakers to 4 ohms), 2 -zapco's 500/1 would also work...
you have some really nice tower speakers ( i have 3 deafcon models 4's) and they need some high quality power to go (they were designed around tru amps)...
