Thanks for the advice so far. The reason I had the carb rebuilt was because of a slight hesitation while coming out of the hole. I noticed that the fuel filter being dirty came up a couple of times. Would this cause to boat to run fine when cold then poorly after warming up? Anyway I'll change it (there are two of them?). As for the timing, it was not touched however I did change the plugs, cap, rotor, points, condenser, etc. Perhaps the distributor moved while doing this. When I describe it as "felling flooded" I mean that if I fully open the throttle, the boat doesn't have any pop, it has a hesitation or surging feeling and will not reach full speed.
