I am no expert, but I believe you could do it either way with the ground. It would be better I believe to run a ground to the block. I am currently running this setup. I have 3 batteries not connected to the altenator and 2 other batteries connected to the engine with a perko switch. I have 1320W going to my amps max. I sat at the beach with the stereo going for about 6 hours with no issues. I have 3 Optima D31M batteries that are 155 hour reserve capacity each. Not sure if that is addative, or how that is supposed to tell you how much time they will last before cutting the stereo. I have been thinking about adding subs to my system and then adding a larger altenator or adding a second altenator for the stereo. I have also been thinking about how to add a few battery isolators or if there is such a thing, a three bank battery isolator. I have a 2 bank charger now, but it is only connected to one bank for just the stereo batteries - should have bought a 3 bank charger but didn't know better at the time. I am going to add a second 2 bank charger for the boat batteries very soon even though I have never needed it - just a precaution. I just connect the battery charger at the end of the day when I put the boat back in storage and have not had an issue yet.
