Old     (michel)      Join Date: May 2007       05-31-2007, 12:51 PM Reply
What should be the engine temperature when the engine is warmed up?
How quick is the temperature rise from cold to operating temperature?
(Ford PCM HO 295HP 1996)
Old     (rickykamberra)      Join Date: Dec 2006       05-31-2007, 1:10 PM Reply
I have an Indmar 350, and the normal engine temperature runs between 180-200 degrees. It usually takes about 5 minutes or so to warm up to normal operating temperature.
Old     (bob_l)      Join Date: Jul 2006       05-31-2007, 3:15 PM Reply
Also depends on water temp. I noticed that in March it took 5 minutes to get to 160 and it stayed there. Last week, it took 2 minutes to get to 160 and never got above 180.
Old     (rallyart)      Join Date: Nov 2006       06-01-2007, 7:26 AM Reply
Temperature should sit at your thermostat reading unless running under a heavy load. If you have a head exchanger and closed cooling with glycol you'll have a 180° or higher thermostat. If you use Lake water for cooling the engine directly you will have a 160° thermostat.
Old     (denverd1)      Join Date: May 2004 Location: Tyler       06-01-2007, 7:36 AM Reply
*a bit of a hijack, but still relevant..
engine temp was acting up on my boat, so i tried to find the thermostat. couldn't find one. Bought a 140* to replace it. Haven't put it in yet.
What problems could be caused by running with no thermostat? or one with a lower "open" temp?
Old     (rallyart)      Join Date: Nov 2006       06-01-2007, 7:57 AM Reply
The engine runs less effeciently when cold so you get more plug fouling and gas mileage is down. You might be able to get more raw power out of it though for a short sprint because the cylinders could fill with a colder mixture.
It's better to find the right one but nothing is going to blow up.
Old     (saroberts70)      Join Date: Aug 2006       06-01-2007, 1:50 PM Reply
nacho. If you run in cool water with no thermostat the engine (at least EFI engines) will run very rich. Even so much as to pump gas into the oil. It happened to me.
Old     (wakesetter101)      Join Date: Oct 2005       06-01-2007, 6:18 PM Reply
Dont run a efi engine without a thermostat. Carb engine maybe but not a efi.
Old     (michel)      Join Date: May 2007       06-02-2007, 8:27 AM Reply
It seems that my thermostat is not working properly. Engine temperature stays low (full left on the indicator). And uses an awful lot of fuel. (is it also possible to lean the engine???)
Parts are very expensive here in Holland. Does anybody know a store in the US where I can order parts?
Thx
