Quite a few people helped me out, and I stole ideas from as many people as I could. A couple of people wanted to know about parts used, sources, etc...., so here goes:
Pro X Series Sacs – V-Drive Set & Tube Sac buywake.com
6 Rule 1100 Aerator Pumps livebaitlarry.com
Qwik-Lok 1-1/8” thru hull & Qwik-Lok QD Sockets flow-rite.com
1-1/2” Groco Thru-hull Scoop Strainer go2marine.com
Contura Black Switch ON/OFF/ON
go2marine.com
(3) PVC ¾” swing check valves plumbingsupply.com
(1) PVC 1” swing check valve plumbingsupply.com
(3) PVC Reducing Tee 1” X ¾” (vent /drain line) plumbingsupply.com
Brass 90 Elbow 1 ½ plumbingsupply.com
Brass Nipple 1 ½ plumbingsupply.com
Bronze 1 ½ Ball Valve local plumbing supply
42 ft of 1” ID Spa Flex Tubing local building material
RV Cable-Actuated 1 ½ Gate Valve w/ 6’ cable local RV store
¾ inch bilge hose local building material
Nylon fittings, clamps, PVC parts, bushings Home Depot, Lowes, TSC
Electrical – wire, fuses, connectors Wal-Mart
Here is the parts list for you visual types:
