Dave, I used to own one. We ran about 700-800lbs in the front, 550 in each back locker, stock center MLS, and another 550 or so on the floor + 3-4 people. If we were missing the people or the center floor weight, I would run the wedge, otherwise I would not (didn't like the way it handled). We had a low end prop (forget what model). We would ride around 25MPH at 85' (although the MPH is kind of arbitrary because the speedos can read differently...) I remember it took a lot of weight to get a big wake, but once you did, it was pretty grande. Very wide. It was not as steep as I like, so you might have to add weight to the back to get it to be steeper. Just play with it. Obviously you may not need to run this much weight depending on skill level. It might make the wake unmanageably wide. Danny
