Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through August 20, 2005
Old    jayazz            07-24-2005, 11:30 AM Reply
Is there a wedge or something similar than can be universally used on any boat, especially outboards?
Old     (gatorhator)      Join Date: Jun 2005       07-25-2005, 7:37 AM Reply
With an outboard you should be able to simply trim up the engine. If that is not good enough look into a product called a dolphin. (Note I have not had an outboard for about 10 years, but that is what i used.)
Old    jayazz            07-25-2005, 10:34 AM Reply
already trimming, and have dolphins any other suggestions
Old     (peter_c)      Join Date: Sep 2001       07-25-2005, 11:16 AM Reply
Add more weight...if you still are not happy with it, upgrade boats.
Old    jayazz            07-25-2005, 11:22 AM Reply
so there are no external fixtures on the market to force the back end down, i wonder why not
Old     (suckbuthavefun)      Join Date: May 2003       07-25-2005, 11:47 AM Reply
www.wakezup.com
Old     (bigshow)      Join Date: Feb 2005       07-25-2005, 4:05 PM Reply
The "Dolefin" is hydrofoil designed to provide upward lift to the rear end of your boat. This is especially helpful for underpowered boats pulling skiers out of the water. I had one on my old I/O it reduced bow rise, and helped get the boat on plane more quickly.
Malibu offers the “Wedge” on their inboards. The Wedge is also a hydrofoil, but it provides a downward lift, I think that I’ve read that the Wedge has the same effect as adding 1000 pounds of ballast.
The Dolefin would work against a Wedge, so if you were to find a wedge for an outboard it would counteract the Dolefin.
DISCLAIMER – Don’t blame me if you attempt the following and SINK YOUR BOAT, cause injury or other damage. If you were to install a Dolefin upside down it seems like it would provide the effect that you want BUT BE VERY CAREFUL. I’m sure that Malibu put a lot of effort, engineering, and testing in to the development of the wedge. The Dolefin is designed to provide a lot of lift at slow speeds. Installed UPSIDE DOWN it just might SINK YOUR BOAT.
I don’t think that the Wakezup can be installed on an I/O or outboard. The text in the link discusses replacing the ruder with the Wakezup hydrofoil. I assume that they mean inboard rudders.
Old     (gatorhator)      Join Date: Jun 2005       07-25-2005, 4:12 PM Reply
Bigshow, you are correct but that is not the whole story. A dolphin on a level or negitive trimmed engine will cause upward lift on the transom, however a dolphin on a positive trimmed engine will pull the transom down in the same way a wedge does.
Old    pate            07-26-2005, 7:40 AM Reply
Tim, Have you seen a Wakezup in action?
Old    janderclandr            08-04-2005, 5:56 AM Reply
I´m writting from spain, i`ve been trying to find the dolphin in the net, but i didn`t find anything. Anybody knows where can i see anything?
Sorry about my english and thanks.
Old     (denverd1)      Join Date: May 2004 Location: Tyler       08-04-2005, 8:57 AM Reply
i saw a pic of the wakezup mounted, but havent' heard any news about it. i'm also curious....
Old     (bigshow)      Join Date: Feb 2005       08-04-2005, 8:16 PM Reply
Alex, try this link. There are a number of hydrofoils, good luck.
http://www.overtons.com/modperl/overtons/order/items2.cgi
