Old     (joran)      Join Date: May 2008       05-07-2009, 11:03 PM Reply
Any advice on upgrading my ballast system? I'm wanting to add another bag in another location and using an over the boat pump is just getting old, I want to automate. I'm planning to use quick connects so I can remove the bags and whatnot. Would it be better to go with multiple aerators, or get a reversable pump like the jabsco one or something?
Old     (nick_in_ssp)      Join Date: Aug 2006       05-07-2009, 11:13 PM Reply
I love the tsunomi pumps, cheap, easy to install and I don't seem to have a problem with them. What kind of ballast are working with now?
Old     (spencerwm)      Join Date: Feb 2009       05-08-2009, 12:09 AM Reply
Ben,
Should be a pretty easy install in your LSV. I think you will like the price of a 2 tsunami pump system. Unless your boat is a 2009 go with the aerators.
Spencer@wakemakers.com
Old     (joran)      Join Date: May 2008       05-08-2009, 2:55 AM Reply
it's a moomba lsv. I want to add pumps for an integrated bow sac. Where do I get fittings for the water intake?
Old     (spencerwm)      Join Date: Feb 2009       05-08-2009, 6:06 PM Reply
Are you going to drill and add another thru-hull stainer or just "T" off the existing thru-hull?
Old     (trace)      Join Date: Feb 2002       05-08-2009, 6:40 PM Reply
www.marinehardware.com
Old     (dreamer)      Join Date: Nov 2008       05-09-2009, 5:56 AM Reply
What is best, T off the existing thru-hull or add another thru-hall strainer? Would adding another port speed up the fill times?
Old     (spencerwm)      Join Date: Feb 2009       05-09-2009, 6:31 PM Reply
I don't think the fill times will change which ever way you go if you are only adding one more fill pump. I say "t" off that thru-hull and add another fill pump. Are you going to add another switch or piggyback off of the center tank switch?
Old     (joran)      Join Date: May 2008       05-10-2009, 5:24 PM Reply
I'm gonna wire into the extra accessory switch on the dash with the bilge/blower/stereo array that's completely unused right now.
