Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through May 25, 2007
Old     (brttkrz)      Join Date: Aug 2005       05-10-2007, 9:14 PM Reply
Saturday I'm going to be using our newly installed perfect pass for the first time. I'm wondering what kind of speed range to expect when making adjustments. Also does anyone have any suggestions for adjusting the KDW and NN. The boat is a 1990 rinker with a 350 and about 2000 lbs of ballast.
Thanks
Old     (billspin)      Join Date: Aug 2004       05-10-2007, 9:30 PM Reply
Be sure to take a GPS unit with you. Use this to calibrate the speed. I have a 2004 22i Tige 340 HP no ballast and I set the KDW at 150 and NN at 70. This might help get you started.
Old     (gmarkham1)      Join Date: Sep 2003       05-11-2007, 4:58 AM Reply
You are going to have a hard time finding someone else using perfect pass on the same boat you have.
However I would start your kdw at 180 and your nn at 110.
This gave me the best results on my old bayliner... but you have more engine, but about the same on ballast!
Old     (snyper1d)      Join Date: Mar 2005       05-11-2007, 5:19 AM Reply
I would try it out as it is. Take the manual with you, and follow the instructions. Every boat will react differently due to factors such as paddlewheel alignment, prop, ect.
Old     (timsown)      Join Date: May 2005       05-11-2007, 12:45 PM Reply
You may also need to install a return spring on your carb depending on how your throttle is linked. Some need it, some don't. If I remember right, the instruction manual mentions this.
Old     (jc245)      Join Date: Jan 2007       05-11-2007, 1:15 PM Reply
Brett, I just went through this same process 2 saturdays ago. Installed PP over the winter and was anxious to try it. Bill is right, grab your GPS for the first time out. The book says to measure your speed at 20mph and adjust from there. I got the boat stable at 20MPH (as read on the GPS) and found the PP was reading 2.6 mph off. Bring the manual with you and use the calibration instructions. Piece of cake, mine is dead on now and WOW, even a total rookie at the helm will give you a GREAT pull with PP. Love that thing! Good luck.
Old     (brttkrz)      Join Date: Aug 2005       05-12-2007, 2:01 AM Reply
Thanks guys. I didn't need the spring the old one worked fine. I am really anxious to start using the thing, everyone says it worth every penny.
Old     (brttkrz)      Join Date: Aug 2005       05-12-2007, 6:08 AM Reply
What kind of speed range should i be looking for? .5 mph above and below, stricter, looser?
Old     (bob)      Join Date: Feb 2001       05-14-2007, 1:07 AM Reply
My I/O usually stays within .2-.5 mph +-, 3400 lb stock boat weight, plus people and gas with an efi 5.0 and 19" 4 blade aluminum and 19'6" long.
