02-14-2009, 8:04 PM
what about vacuum infusion?
02-15-2009, 5:02 AM
Hey Petr, The folks at Coil are pretty guarded about their process. From what I can tell the blank is a 1 pound EPS and it isn't sealed. I don't know if not sealing it has some major impact on the board's performance. However, not sealing it would preclude infusion, as the EPS would just drink the resin as it was pulled across the board. Not to mention that the 1 pound EPS would deform at the pressures needed for infusion. I was reminded, yesterday, that a truly skilled glasser can get the same resin to fabric ratios as a bagged board using just a squegee and maybe a wetout table.
02-15-2009, 11:43 AM
i see you are going to see if this tech/stick will work for james
02-15-2009, 1:43 PM
Yeah. This year I want to get a solid test on stringerless and a hollow.
02-15-2009, 4:44 PM
i have ridden nothing but stringerless and dont know how the others ride, let us know if the coil snaps back like they say it does.
03-10-2009, 9:43 AM
Surfdad I know its got to be done by now,???
03-10-2009, 11:24 AM
Have you noticed, in this industry, when you get that return phone call or email that starts out: "Dddddduuuudddddddeeeeee" That it will be at LEAST another month before "whatever" arrives.
03-10-2009, 4:29 PM
its in every industry , that you have to wait on other people to do the work.
03-16-2009, 4:53 PM
WILL YOU USE THESE FINS
03-16-2009, 6:37 PM
That's a LOT of Scimitar's! That's not the pivot rear, so either the 375 or 340 quad rear's? James is favoring the 3/2/1's of late. (Message edited by surfdad on March 16, 2009)
03-17-2009, 10:38 AM
rear is a 325 , enough to hold but still able to break loose
05-07-2009, 6:24 PM
That's a sweet looking board!
05-07-2009, 6:45 PM
Nice & clean
05-07-2009, 7:11 PM
So its 4 layers of 4 oz per side and what type of nonwoven fiber material is it??. looks great and just in time for the weekend
05-07-2009, 7:22 PM
Thanks guys. Brewkettle, I don't know what the material on the rails is - they say it's some type of microfiber. It's embedded pretty deep in the resin, so I can't make heads or tails of it...but...I swear I've seen that mesh in a garden department of a big box store.
05-07-2009, 8:08 PM
need a closer pic of the secret material
05-07-2009, 10:59 PM
That is a wicked sweet lookin' board!
05-08-2009, 11:41 AM
finally!!!
05-08-2009, 12:16 PM
Surfdad, what is the weight without fins,
05-08-2009, 1:33 PM
5 pounds. It's the same weight as James TWP.
05-08-2009, 7:51 PM
Here is a close up of the "secret material", Brewkettle. I'm not sure if you've ever seen netting that commercial nurseries place over plants to birds out and the sun off - that's what it reminds me of.
05-09-2009, 6:02 AM
looks cool , is it just for looks or does it add stiffness??, i wish it was lighter but 16oz. top/bottom i guess its fine.
05-09-2009, 6:35 AM
Yeah if you figure 16 oz of fabric and probably 32 oz of resin it's 1 pound of foam, boxes and this mesh. We'll see how it rides today, but the folks at Coil have represented that the microfiber adds stiffness and flex return. They messed with carbon but found that to be too stiff. The Coil folks acknowledge that their boards aren't the lightest, they instead say that the love FABRIC and contend that the extra fabric offers a more substantial board and the flex return is more pronounced. We'll see if the hype is legitimate. Mostly it's been my experience that marketing claims advance much further than the underlying reality I've been impressed with the use of perimeter stringers, but not the longevity due to ripping along the stringer. James current board has a patch over most of the tail, but that changes the performance some with less flex and more weight. Proctor's Kevlar and Carbon Patches are interesting. The Kevlar helping to reduce underlying heel dents and the carbon over the stringers spreading the load some, as well as, adding additional stiffness. We'll see how that works also. The Coil, if it can harness flex and return like the perimeter stringers, would address the durability issue. I have my fingers crossed!
05-09-2009, 5:49 PM
Looks dope!!
05-09-2009, 6:15 PM
05-09-2009, 6:46 PM
James always seems to get a little more air than Jeff does
05-09-2009, 7:00 PM
Did you mean, hair?
05-09-2009, 7:48 PM
No, but let's be clear; it's both.
05-10-2009, 7:32 AM
So true!
05-10-2009, 9:38 AM
No, James just always snaps shots of Jeff landing his air's. Just look at the splash down on that last one he must have had 3' there.
05-19-2009, 8:20 AM
LOL - YEAH! What Hate N Pain said. (How much do I owe you for that? ) I've done a bit of "looking" at the Coil and it's not fiberglass in the exterior lamination. Well, it's not FULLY fiberglass. If you look at the pictures above it's a SUPER bright white and up close, you can't see any foam or the telltale signs of pukas in the EPS. At least SOME of the fabric covering it, is opaque and the only fabric that I know of that has the characteristic super bright white and stiffness is Spectra. In looking at it, I think that at least one layer, perhaps two is spectra laid on a bias. Then, one layer of a 2 oz or 4 oz e/s-glass on top. The folks at coil did a concept board using a carbon/spectra blend fabric. I know that some of our old wakeboard ropes used Spectra because it is no stretch and it's specific gravity is lower than water so it floats. The black "microfiber" over the tail and along the rails looks to be a plastic mesh that is used when applying a thick layer of mud on sheet rock. It gives the mud something to grip to. Interesting use of material.
05-19-2009, 10:02 AM
Great work inspector , found this on Sways http://www2.swaylocks.com/node/1024029 (Message edited by brewkettle on May 19, 2009)
